racyroy1
Hello,
Is there a difference between disc brake UCA's and drum UCA's?
I bought a disc brake coversion off of a 74 valiant, it came with upper control arms. in one control arm i can get the new ball joint in, in the other i can't, i'm assuming that maybe the one is damaged and the ball joint won't fit. I have a set of UCA's that came off of a non disc brake 72 scamp. Can I use the non disc brake UCA with the disc brakes as long as i use the bigger ball joint or will the disc brake ball joint not fit the drum UCA.
Thank you for clearing up my dilema
kevin
kevin
