Captainkirk
Old School Mopar Warrior
My 340 has a set of late '72 1.88 "J" heads. Would I experience any issues upgrading these to 2.02 intakes, and how much will it buy me on a HP street motor?
What does the rest of the build look like?
cam
intake
carb
compression ratio
exhaust
etc...
So far....
+.030 Speed Pro forged L2316F 10:1, forged crank. No decisions on cam or valve train yet.
Intake, Air Gap with either Holley 650 DP or TQ
All negotiable except the pistons and crank
If the block is milled to blueprint height and the crank is properly indexed those pistons should be .018" out of the hole @ TDC. Making some relatively well placed guesses on the valve relief volume and what gaskets you'll likely use, the compression should be around 9.7:1 with ~68cc chamber, which is about on par with J heads. That could go either way depending on what type of valve you use.
Another question is:
Do you need to replace the valves?
If you haven't decided on the end goal of the engine, or what cam you wanna use...
More of this...Okie dokie.If the piston isn't .045 out of the hole you won't be near 10:1
Without being properly blended, not much more...but if bowl blended right you should see around 225-230 cfm @or between .450-.500 lift. It can be a good thing to build around the heads...My 340 has a set of late '72 1.88 "J" heads. Would I experience any issues upgrading these to 2.02 intakes, and how much will it buy me on a HP street motor?
And or if the chambers are milled down, the new 2.02/1.60 valves eating up 4-7 cc's ....the piston can stay where is.
Captain, get the short block together, have the valve work done and then cc the heads before cutting them...then you can dial in the best you can get without reinventing the wheel. You can take the heads down to 60 cc if you want, Damn near closed chamber and plenty deck thickness, I do it a lot to know.
Didn't get past the 1st line of yellows post... Most are 72-73 cc a few have been 69cc, the valves are a big part of how large they are, port volumes as well. 1.88 are larger P.V than 2.02 ports from the factory. I know we all like to make points...but you can't leave the rest out...or is exactly like saying .."you can only do it this way".
You would have in search of flow around 290 cfm or better and at .600+ to have an issue with loading on the side of the port induced by heavy milling.
Last I checked...the captain isn't doing anything of the sort. You gotta attack it for what it is...
OK...my bad. Forgot to mention:
1) These heads were previously cc'd...67ccs
2) Block has not been decked or heads milled. I can check "out of the hole" once it's assembled, just trying to get my ducks in a row.
My machinist tells me 2.02's won't do me any good below 6k and may actually hurt bottom end torque but every Mopar pub I've read says "if ya got 'em, flaunt 'em" WRT 2.02's
This will be a A833/3.91 gear car...
He is speaking from a general point of view that is misunderstood, what is comes down to in this case is....flow is power, the bigger valves give more airflow when cut and blended right, and especially the lower lift that is handy in filling the cylinder. These ports are small...so small that even if you opened them to be .060 thick in the entire port walls,floor,roof...the fps/air speed would be huge. Your machinist is not a this or that...he is just a machinist. The numbers I post are not BS, anyone who plays with sb mopars knows the x, j, o, u, blah blah are easy to get to 240 cfm, its not rocket science or a secret and yes you remove a bit...but It's no secret to those who work with these that the real work is getting up past that and controlling fps/air speed so it holds at lift.OK...my bad. Forgot to mention:
This should be fun to watch the replies...![]()
Not necessarily.Do you need to replace the valves?
ok, port velocity and shape are everything, port speed fills the cylinder, not valve size!! as for power, we have tested 2.02 and 1.88 valves on real flow bench. the 1.88 has more port velocity, vs the 2.02. flow is close. the X head was designed for 2.02 valve, the others were designed for 1.88 valve. now, to compare power, in stockers, the 1.88 headed engines are as fast as 2.02 headed engines. some exceptions are there. Chevrolet, went to 2.02 valves years ago. it was a marketing ploy! we tested a chev head with 1.94 and then he opened up bowl , installed 2.02 valve and retested, flow and velocity loss. imagine that!! valve type and seat angles are important to flow gains. I realize you can't brag on 1.88 valves. 2.02 , you can. lol. BTW, a 1.88 valve 340 runs to 7300 rpm in traps, doesn't lose power. 283 chev super stockers, with 1.75 valves run 9200 RPM. no power loss.So i would let them in.
Your machinist is right when he said it only hurts you under 6k rpm.
I made the same mistake.
Build a 340 with RHS Indy heads with 2.02 heads.
After i sold the engine, i build exactly the same setup again and choose 1.94 valves.
It pulls stronger under 5k rpm as the big valves.
It´s only really remarkable over 5500rpm with the big valves!
So if you want to rev like 7500rpm, it´s ok with the big ones. Otherwise, let the small ones in it. Gives you more power from the lower rpms.
