I have a 1973 Plymouth Duster with the rare Space Duster Package (feel free to correct me if I am wrong). My Duster has a 225 /6 mated to the A727 Torqueflite 3 spd auto with the 7 1/4 rear end. My dad has the LJ Wrangler with the 4.0. I was wondering if anyone knows if it's possible to swap a 4.0 fuel injection setup onto the ever so fabulous 225.
That "ever so fabulous" 225 motor has, bolted to it, a NOT SO FABULOUS cylinder head, which you are stuck with. The bottom line is, the head has such small valves and ports, adding a free-flowing, electronically fuel injected intake system isn't going to pick it up very much, because the restriction to flow is not going to change much. It's the head.
You can spend $1,400.00 on porting the head, and install bigger valves, but it will never really perform well... the head is THAT bad...
Our friend PISHTA, though, has designed a neat little turbo mount that BOLTS (no welding) onto a stock slant six exhaust manifold. and makes turbocharging the slant six a whole lot easier than it used to be.
The turbo makes an end-run around the breathing problems created by the highly-restrictive 225 head, and is a sure cure for the N/A blues that seem to accompany efforts to have a reasonably-fast slant six powered Mopar, naturally-aspirated.
Turbocharging is neither easy nor cheap, but is a prettty viable way to get 350 horsepower out of the leaning tower of power.
350 horsepower is NOT easy to come-by naturally-aspirated, fuel-injected or not...:violent1:
I'd suggest you look into it...
