'64 Cuda
A few of the people here on the forum know about this, but I'll start at the beginning.
In September of 2007 I bought a balanced 360 LA roller cam short block minus cam on eBay. It had reworked rods with high strength bolts (ARP? don't recall at the moment), main studs with a windage tray, heavy duty Mopar cast crank, & coated bearings, performance dampener, etc. While waiting for the block to arrive I started accumulating parts based on it's deck height & my intended use, etc.
Without naming names, (several people have told me I should be posting his name all over the place) I tried for over 15 months to get the guy to ship the thing to me. Whatever he might tell anybody about this ordeal, I have all of the emails that went back & forth between us & can back up my side of the story. I heard every excuse in the book. Finally, after finding out that I was trying to locate him by contacting others, I guess he got pissed at me. He refunded my money, plus $50, 16 months to the day after I paid him.
So, now I'm starting over. I have purchased a running, untouched 360 roller cam engine from a 1991 Ramcharger & will pick it up this weekend.
I have the following parts for it.
Edelbrock 60779 heads
Complete new Six Pak setup (manifold, carbs, linkage, air cleaner)
Comp Cams hydraulic Roller cam 230*/236*@50 110CL 4* advanced w/.510"/.520" valve lift (1.5 rockers) with new Mopar Roller Lifters
Comp Cams Roller Rockers (The steel ones, not aluminum) with shafts
MP 3690426 Electronic Ignition Conversion kit
Double row roller timing chain set & chain tensioner
I also have other parts laying around. A stock 340 flywheel & a 30 year old performance flywheel (less than 10,000 street miles on it), windage tray, a hardened tip oil pump drive, other odds & ends.
This is going into my 64 Barracuda street/play car with a 4 speed & 3.91 gears.
Now for my dilemma. Do I build the engine as a 360 or bite the bullet, spend a bit more, & build a 408.
If I build a 360 I'll either have to find a 360 flywheel (I think these run about $300) or rework one of the ones I have to work with the 360 balance (kinda' hate to mess with the hipo flywheel, not sure that it matters, though). Maybe it could be internally balanced (cost?). Or maybe there's an internal balance replacement crank, I haven't looked much yet. Either rework a set of rods (I think I have a set of arp bolts) or maybe Eagle I beam rods. Also have to buy pistons. Maybe a little over $200? Balance the thing-$150 just guessing.
By the time I buy rods, pistons, (maybe a crank, haven't torn mine down, how good is the stock 360 crank?) would I just be money ahead to buy an internally balanced cast crank stroker assembly? Maybe $1400 to $1500? Any recommendations as to kits? I could use my flywheel as is. A lot of the other things I'd have to buy no matter what I build.
One other concern with a stroker is that my end carbs are for a 340 & I've seen it recommended to use 440 carbs. Can I rejet (was planning on converting the carbs anyway) & get by with the carbs I have?
I'm sure I've forgotten a lot of things, but at least the door is open now.
I'm wide open to anything anybody has to say. Have at it.
