k member?
The k member will bolt up to the car but without special conversion mounts your v8 will not bolt to the k member
I thought that all the early 64-66 K members are the same-no difference between the /6 or V8? Steering linkage is not the same.
No difference between /6 and V8 k-members on the early A-bodies. As a matter of fact, there is no difference in the motor mounts, only the engine brackets.
