kb 107 pistons and nos
earthmover
in the tire smoke
nc
anyone run a good shoot of nos on the kb piston???? lookin at maybe 100/150 no more...got enough parts to put a good little 360 tog. for the 73 dart swinger that we have.. all thats needed is a block machined and rings/bearing we we have all the other parts..
also let hear what kinda power this thing would make with out the nos
30 over 360
stock crank
kb107 pistons on stock rods with good arp bolts
comp soild cam 282xs 520/540 lift with 1.5 crane rockers
xcal intake port matched to gasket
j heads some port work done flow about 250 @500
holley 950hp
727 with 8" 5600 verta or 9.5 5000 verta
4.56 gears in 8 3/4
ss springs
what you guys think it should make oh im lookin about 10.5 comp with the heads at 70/72cc so trying to run highest pump junk lol
so lets hear about the nos and what kinda power it should make without ..
my 70 duster went 7.44 with the same cam and about the same port work on the heads in a 30over 340 but about 400lbs lighter..could not get it to stick the back slicks for some reason car would leave with tire in the air and set it back down 1.67 60' best could get...:toothy2:
Should be in the low 500 range with a 100 shot
Good enough if the chassis works to run 10.80-10.90 is my guess at 122-123. Might run better. Make sure the top ring is gapped per spec from KB using n2o.
thats bout what i was thinking going to make this a driver thats why i say i will hit it with so nos..thanks mike
