Key light won't go off 69 Dart
JeffreysDart
Redwood City CA
Just replaced all the fuses and now everything works and it works so good that the light above the ignition key in my 69 dart will not go off?
When the battery is connected this is the only light that is on. This is the light were right above the ignition key.
How do we get it to go off? All map lights are switched off?
It's in the dash harness, usually right around the left side of the ashtray.
It's a longish cylinder. Thinner and longer than a turn signal flasher.
You don't unstick, just replace.
I have those for $20 shipped if you need one
Just in case anyone else has the same problem, I was able to fix my timer without replacing it. I opened up the case and carefully bent the coil-wrapped tab so it sits a little farther away from the contact. It's been working for over a year since then.
