Kframe, engine bay, front suspension questions
After doing some reading it looks like the L and R go to the rear. I took LCA right off to put tbar in to rear socket from front. Then reinstalled LCA. Combo of antiseize and grease in the sockets and on ends.
Torsion bar adjuster in loosely. Thanks to Roy, @SGBARRACUDA. Not sure whether its clocked correctly, back line on hex end vertical.
Still gotta wrestle the boot onto the crossmember.
Thanks all
Drivers side in. All loose and hanging. Gotta figure out ride height next. Anyone got a measurement where my jack stand is to the ground? I'm at 21 1/2" right where front kframe mount on driver side bolts on.
Thanks!
I did my engine bay and door jams and the area behind the fenders and it took right at a quart of bc/cc i did it outside using spi epoxy, moto base, and spi universal clear a harbor freight compressor and harbor freight hlvp spray gun.
Thanks all
Just did mine last week. They were vertical
Thanks!
Turn them in 10 turns from all play removed. Should be close. Remember not to do final torque on LCA. Just finger tight till final ride height set
Picked up Mevotech balljoints yesterday and some other goodies for the front end. Got one bolted to spindle. Holes lined up good but overspray was making the bolts bind a bit.
Dorman rubber brake lines dont fit in the bracket, so gonna have to grind 1 end if not both :BangHead:
Also bought nickel/copper lines and bent them for the jump lines on calipers.
WAAAYYYY nicer to work with than the standard steel lines. Might shorten them an inch or 2. Gotta get them mounted in car to see if they're in the way 1st.
Thanks again for all the help.
Thanks, I was able to bend the lines by hand. $3.50 each already flared. I was shocked how cheap they were.
Yeah the rubber hoses arent going to work dangit(dorman h71319) I have the star shaped bracket in the wheel well. Also the hose brackets that mount to caliper are the "D" shaped ones for 70+.
Thanks.
those lines look great. any pics of the issue with the hoses?
I'm sure it was tough to let it go but life's like that, Steve.
Where is it going?
