[SOLD] LA 318 With Magnum Heads
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Located in middle Georgia about 20 miles NE of Macon.
Price is 2K dollars, OBO and is very negotiable. Make me an offer. You'll probably be loadin up a 318.
This engine will produce an honest 300 or a tad more HP and be pump gas friendly.
1986 318 short block, .030 over with stock .030 over flat top four eyebrow pistons. Moly rings, rebuilt oil pump with the MP high pressure spring. NOS TRW remanufactured rods with new rod bolts, resized and weight matched.
.010/.010 crank and bearing kit. For the bumpstick, I went with a Lunati 60403. Magnum heads in great condition with fresh valve job and milled to produce a blueprinted 9.2:1.
Cloyes true roller timing chain with solid rollers. MoPar timing chain tensioner.
I used these valve springs: http://www.hughesengines.com/Index/p...=&partid=10280
These retainers: http://www.hughesengines.com/Index/p...z&partid=23197
These locks: http://www.hughesengines.com/Index/p...z&partid=25636
These pushrods: http://www.summitracing.com/parts/SUM-1457650/
Edelbrock Air Gap Intake.
I will include the Magnum serpentine bracket and correct Magnum P/S pump and bracket.
Thats a nice setup there. If I had the funds and were closer I would have it on my stand already.
Thanks. It's gonna be a boni-fide 300 plus HP 318 for sure. It'll run some 12s in a properly equipped A body.
BUMP. Somebody needs a hot little motor.
Sweet mill ,Rob. Can't build one,for less than 2500-3k ,at a hack shop.
Thanks. I thought it was a decent price too........just like the Hemi. But what do I know obviously?
Thanks for the bump, DarTT. My askin price is 2K, but I'll certainly take 1800....or any reasonable offer.
