LA to magnum
eccentricMagpies
Wisconsin
When rebuilding my 360 i had bought magnum heads to replace the LAs.
I'm looking ahead to when i install the headers and need new bolts for the heads to Headers.
Are these the same bolts I'd use for the LA or completely different set?
thanks
john
thanks
john
I used the same headers and bolts when I swapped out my 318 for the magnum motor, so they should be the same.
Okay. Thanks all
Second question: The bolts from the former heads are pretty much junk. Any recommendations on new bolts? There seems to be a wide variety out there.
Okay. Thanks all
Magnum head bolts are "stretch to yield" and really should only be used once.
OE head bolts for your swap should be just fine, and you can get them about anywhere.
