Last one to post in this thread wins!
Thought about playing Garfield today and staring at the inside of my eyelids. Lol
Ok the center bolt holds the float bowl and the other is a drain to empty the bowel. If you gently clamp vise grips onto the fuel line unless it had an in-line shut off. Then have a small container to catch the gas when you take the center bolt out then you can look at the tiny small holes. One goes down the center of the bolt and then there is a hole that runs horizontally. Like I said before get some wire and strip it back an inch or so and twist two strands together and slide it down the center hole. Probably a minuet bit of dirty or some obstruction. It doesn't take much to clog it up or restrict the flow. If you do find dirt in the holes then clean the tank out. Also look inside your gas can and probably find dirt in the bottom. If you do dump it in your car/truck clean out the can and put fresh Premium gas in it.. BTW you did check for spark didn't you?
thanks, i will get to it tomorrow
yes, i did check for gas
but, i dont think you are thinking of the right carb
the whole thing is made out of plastic, and it has two screws that hold it on
ill post some pics when i get it apart
Just for S and giggles. I ran a ground wire for the spark control module just to make sure it is getting a good ground. I did use bigger screws to secure the module but with all the pint on the firewall This might be the problem for the no start as they have to be grounded. Took it for a drive and started it several times, so far so good but time will tell. If it does it again there might be a Black Cuda going cheap LOL
Wow..never seen a plastic one before. I had the proper carb for your machine but gave it all away when I got out of repairing small engines 5 months ago. I would have mailed it to you. Being plastic I'm wondering if the baseplate might be warped or even cracked and sucking air.
Think this is the problem. Pretty simple fix
That is definitely the carb that's on there
I did not dare muscle the "cartidge" out yesterday, now that I know i can, I will tomorrow
Thanks
By the way...where's that guy from?
He had a rather amoozing accent, I wonder if he's a yupper
Gonna take the scamp on a long road trip this Saturday to Fargo and back it will be a 600 mile trip to make sure it runs out real good and nothing falls off. lol
Gonna see if I can stop and see John and check out his Demon and see my boys also.
Before I put the interior in I want to make sure everything is fastened down good and will recheck every nut, bolt and wire.
Good excuse to get out of the house and have some fun...
Enjoy Fred. Dont forget the gas card lol. Give John a hug for me... JUST KIDDING!!!
Well gentlemen, looks like I’m staying put. Boss stepped up didn’t want to loose me ,good feeling , the other job said if I showed up with my box when ever that is there would be a job there also even better feeling , good day , going to polish the Daytona. Cheers !
Good for you Biff. Well played.
Always feels good to be wanted at work for sure.
But knowing you your a good worker and the boss I think knows it.
