LCA IS THIS NORMAL
74 360 dart sport
Montevideo
Hi I hope @Jim Lusk sees my pictures I am rebuilding my LCAS In the 1 picture I have the level so you can see the unevenness and in the other other I have the level down towards the bumper plate I am wondering if the 1 side is bigger in diameter or is this thing bad thanks Tom
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Hi I hope Jim Lusk sees my pictures I am rebuilding my LCAS In the 1 picture I have the level so you can see the unevenness and in the other other I have the level down towards the bumper plate I am wondering if the 1 side is bigger in diameter or is this thing bad thanks Tom
If you want a particular member for any reason, here's how you tag them. @Jim Lusk
Doing that sends them a message so they know to look on this thread.
Kern Dog
I like girls that wiggle
Granite Bay CA
That control arm is bent. In some cases, you can bend them back in a press but since these are not that hard to find, I'd look to use a different one.
hemi71x
Rancho Cordova, CA
Well, i'm not Jim Lusk, who i do know, but another Jim, Jim Valuckas.
I personally have never seen a side of an LCA, with that big of a larger diameter than the other side.
But that side is most likely a bit bigger.
I wouldn't worry about it at all.
I think it's just the way that one was stamped out, back in the day, at whatever manufacturing factory did the work.
I currently have a pair of LCA's for sale in the for sale section on this forum.
Look at them for picture reference.
72bluNblu
NorCal
The diameter is not the same on both sides. You can just measure it, which will tell you it can’t be “level” all the way around. The halves of the LCA are not mirror images of each other. That LCA is spread apart pretty far, but it can be sorted out if you box it.
When I do stock LCA’s I add the boxing plates to the bottom of the LCA but I also add a strap to keep the end from spreading apart like that.
You can see, especially in the bottom picture, that the strap isn’t “level”.
74 360 dart sport
Montevideo
Those look just like mine the set you have for sale
autoxcuda
Look at the from top view.
The one of the left is bent at the lower ball joint cast iron forging area
Jim Lusk
Fresno, CA
You've got some pretty good answers already. Best is to replace the arm. The sway bar tab can be cut off and moved to another arm.
