What is the primary use of the car?
SS springs are for drag racing. They were designed for getting tires to hook on launch. You can run them on the street, and a lot of people do. But the spring rate is pretty high (like 160 lb/in for the 002/003 springs), higher than I like to run at the rear axle on a street car, they make the car ride pretty stiff in the back. And that's coming from a guy that runs 1.12" torsion bars with a 300 lb/in wheel rate up front. If it's just a weekend car it probably won't matter much. If it's a frequent or daily driver, you'll get sick of them IMO.
Stock /6 springs were like 85 lb/in, the XHD's are 110 lb/in, and most of the autoX and handling cars use something in the range of 120 - 130 lb/in. For a street car, I'd be looking somewhere in the 110-130 lb/in range.
Important stuff.
If you're on summit racing, they don't give the spring rate.
I was on the phone with ESPO today and she said the 340 spring's spring rate was 130 and 6 leaves. I wonder what the spring rate would be with a plus one or two.
Yup, bolt right in.
Check your front hanger bolt diameter if using the original ones.
I have no problem with the SS springs on the street so far. Car sits level with my butt in the seat.
Not an overly harsh ride at all IMO, feels substantially better than my F250 unloaded.
Now if I'm hearing this right, good Point. With SS springs, You could reverse sides with the SS springs and counter the xtra half leaf with your body weight.
Or U could get rid of the half leaf.
And if you think it's too high in the back, get an adjustable front hanger and raise the front of the spring, which will lower the rear end.
And this will hopefully place the front spring eye above the neutral line which will help in body rise if UR drag racing. If you want rise and not squat.
Does this jive ? LOL ! This stuff is new to me.
This will change your pinion angle, but may not matter.
Like some you guys are saying, I don't mind the ride either, but it's not a daily driver. I have the 002,003 springs but there is the 863,864 ones for a 2800 lb car. By the old Chassis Book they are both rated 160 Spring Rate.
Is this long enough or what. LOL
OP what are you going to be doing with your car?
