67Dart273
If it was run on the dyno, the rings should have seated pretty well way before a power pull. I'd be pulling it apart and find out why they DIDN'T seat.
YUP
Hey Guys,
I have been getting what I think is excessive crankcase pressure. The dipstick is pushing out and I have been getting oil leaks (even on the dyno). I have the PCV connected and I have a breather on the other valve cover. After the installation and modification of the breather (added extra breathing holes) the dipstick isn't pushing out however I still have oil leaking on the exhaust and I notice oil leaking out of the transmission bell housing. Additionally I am seeing a oil film on the rear bumper and trunk panel. When I got the short block from the machine shop I noticed that I was able to rock the pistons slightly in the bores (is this normal for forged pistons?) All of this prompted the leak down test. This was done dry and on a cold engine but the results are troubling, what do you guys think?
1 = 12%
2 = 16%
3 = 3%
4 = 11%
5 = 7%
6 = 4%
7 = 12%
8 = 6%
With it blowing oil when on the dyno theirs no way in hell I would of taken it from them. It needs to be fixed properly and right now. Is it possible the rings were installed upside down? I know **** can happen, but the builder should of never let it leave his shop.i would be so totally embarresed if it were me. Kim
Never thought about that, good point. I have been putting the Piston at TDC and introducing 100 PSI but I haven't had the engine move even with all of the plugs removed. I am getting ready to call my engine builder to discuss this with him.Brian's right; it's true, at 80psi with the pistons at the top, it is dangerous.
but your results will be about as accurate as possible.
I use a 3ft pipe over the 20" bar. I set the piston to TDC, or a hair early. Then introduce the air very slowly, hanging onto the bar for dear life, and adjust the crank as may be necessary. If the crank flips over it will usually loosen the crank bolt.
My tester is home built with;one regulator,one gauge,a restrictor, and a ball-valve on the end . I dead head the gauge and set the pressure, then connect to the cylinder with the ball-valve closed, then slowly open the ball-valve. If the crank moves,I close the valve and reposition then repeat.
To figure the LD in percent with one gauge, you have to do the math. No big deal, and most times I don't bother, cuz I'm not looking for absolutes.
That's true, at 80psi with the pistons at the top, it is dangerous. Thanks Brian for the reminder.
It never should have left his shop like it is, but good luck with driving it, keep us posted, it can be quite educational for all of us!Alright so I talked to my engine builder and he said that I might need to take it out and romp on it a bit. Cruise it down the interstate with short full throttle bursts. He said that if it doesn't seat the rings that he will do a leak down in my car to see what's happening, stay tuned.
In my humble opinion I would only do that if he is willing to stand behind any damage that may result from doing so. I suggest pulling and bringing to him now for inspection. I know it is painful to pull a new engine but you have big money into it already, don't risk more. That engine won't come close to working as hard in the car as it did on dyno, I'm surprised the guy even suggested it. Imho, if rings didn't seal on dyno then they never will. I'm sorry your project has been difficult so far Glenn, hopefully it gets sorted out soon.Alright so I talked to my engine builder and he said that I might need to take it out and romp on it a bit. Cruise it down the interstate with short full throttle bursts. He said that if it doesn't seat the rings that he will do a leak down in my car to see what's happening, stay tuned.
I will try short full throttle blasts at 60 MPH along with gearing down when I come to a stop. I will NOT beat the dog snot out of it. If I don't see any improvement it will be going back to him for sure.In my humble opinion I would only do that if he is willing to stand behind any damage that may result from doing so. I suggest pulling and bringing to him now for inspection. I know it is painful to pull a new engine but you have big money into it already, don't risk more. That engine won't come close to working as hard in the car as it did on dyno, I'm surprised the guy even suggested it. Imho, if rings didn't seal on dyno then they never will. I'm sorry your project has been difficult so far Glenn, hopefully it gets sorted out soon.
I will keep everyone posted.It never should have left his shop like it is, but good luck with driving it, keep us posted, it can be quite educational for all of us!
It won't/shouldn't hurt anything to do that. Sounds like a probable long shot at this point but it is no real effort.I will try short full throttle blasts at 60 MPH along with gearing down when I come to a stop. I will NOT beat the dog snot out of it. If I don't see any improvement it will be going back to him for sure.
Unless you're one of the 3 stooges... no one should be getting injured while doing a leakdown test.
Try to hold at 90* off TDC and at 100 psi and then tell me that.
