Leaking power steering box - NEED Help
Suspension, Steering and Chassis
  1. Cazbah362
    Cazbah362 Well-Known Member
    841
    71
    Nov 7, 2011
    Nevada
    Local Time:
    7:59 PM
    My power steering box is leaking and it looks like its right around the seal, I would suspect this is common in older car, both my 1971 Dart and 70 Challenger have this issue. How hard is it to fix? Do I need to pull the entire box out? Is there a rebuild kit? any one have a how to do thread I missed?
    Thanks
  2. BillGrissom
    BillGrissom Well-Known Member
    7,615
    501
    May 10, 2009
    Sacramento
    Local Time:
    5:59 PM
    I made a post a few years ago w/ photos. Search for my name.
    3 seals, if you count the sector shaft top. All seals can be replaced in-car. The lower seal most commonly leaks. One member said the dealer trick was to blow it out w/ hydraulic pressure (run engine, turn steering to stop), after removing the dust cap and snap ring. You need a Pitmann arm puller and snap ring pliers ($10 & $15 set Harbor Freight), plus a deep socket to hammer the new seal in. Lower seal kit is ~$10 or full kit ~$25 on rockauto. Your Dart has the early small shaft (1972-) and your Challenger has the big shaft box used on all B, E, C and 1973+ A's.
    Personally, I would pull the gear-box since removing the steering linkage is the hardest part. Plus, I like to de-gunk, de-rust, and re-paint everything.
    • Like Like x 1
    • Cazbah362
      841
      71
      Nov 7, 2011
      Nevada
      Local Time:
      7:59 PM
      Bill - Thank you, I have an Ebody setup already pulled, so i may practice on that one first and see how I do.
    • franktiregod
      franktiregod SAWB
      839
      11
      Jun 1, 2004
      Covington, Georgia
      Local Time:
      8:59 PM
      Im not saying try this. I am only telling a story.
      My Valiant leaked p/s fluid. Each time I drove it I had to fill it up. Well a couple of months ago, I wanted to drive it but the p/s was almost dry.
      I looked in the garage and I didnt have any p/s fluid or tranny fluid to put in it. I didnt know what I was going to do and then I saw some hydraulic jack fluid. (with leak sealer)
      I poured that stuff in there and it is still in there. I havent added any fluid since. LOL
      • Like Like x 1
      • Cazbah362
        841
        71
        Nov 7, 2011
        Nevada
        Local Time:
        7:59 PM
        Frank - Great story - What really can it hurt? THANK YOU
        CP
      • pishta
        pishta I know I'm right....
        21,804
        11235
        Oct 13, 2004
        Tustin, CA
        Local Time:
        5:59 PM
        That jack oil with sealer probably has about 10X the stuff that makes seals expand, good job! I have filled jacks with power steering fluid too, probably not the best but it has worked since then.
      • KitCarlson
        KitCarlson Well-Known Member
        2,582
        472
        Jan 17, 2008
        Middle Tennessee
        Local Time:
        7:59 PM
        I just replaced the one on my input shaft. It was dripping down the box and off the output shaft. To pull the seal, I drilled a 1/16" hole in the outer metal, then screwed in a drywall screw about two turns. A pliers was used to jerk the seal out by the screw head. A crack was found in the 42 year old seal. A long socket was used to drive in the new seal. No leaks.
      • Alanstoy
        Alanstoy Well-Known Member
        129
        73
        Aug 1, 2011
        Auburn Washington
        Local Time:
        5:59 PM
        I have a 1967 Dart w/273.
        Im having a simular problem with my power steering box leaking at the worm shaft. Where the column connects to box. Pretty bad leak, I am hoping that there is just one seal there to make it a semi easy fix? I know better than to ever say the word EASY. Lol But one would think and hope anyways. Am i wrong on this? I really dont want to remove the entire box if i dont have to,Tho i have an other box if needed.
        Might have to try the jack oil with leak stop. sounds pretty reasonable.
      • RedFish
        RedFish FABO Gold Member FABO Gold Member
        25,166
        3865
        Sep 5, 2007
        Local Time:
        8:59 PM
        To replace the upper seal in the car I pull the steering column all the way out.
        When the parts are severly worn, replacing the seal only slows the leak.
        • Like Like x 1
        • plum crazy dart
          plum crazy dart Well-Known Member
          2,825
          93
          Apr 7, 2012
          agawam, ma
          Local Time:
          8:59 PM
          I've got a leaker too. I tried lucas ps stop leak and that didn't work Guess I'll give jack fluid a shot. It would be soooooo nice to get it to stop leaking. That was the winter project that didn't get done. All the cosmetic stuff did though :)
        • Alanstoy
          129
          73
          Aug 1, 2011
          Auburn Washington
          Local Time:
          5:59 PM
          Thanks for responce RF, Yea i think the rest of it is ok. from what i could tell with the little bit of driving i have done with it. So it is just one seal?
          I already have column out, and ready to do this. Lol
        • RedFish
          25,166
          3865
          Sep 5, 2007
          Local Time:
          8:59 PM
          Yep, typical little shaft seal.
          • Like Like x 1
          • Alanstoy
            129
            73
            Aug 1, 2011
            Auburn Washington
            Local Time:
            5:59 PM
            Thats what i wanted to hear, Thank you again RF Much appreciated :)
