Ok guys, this is a strange one. i rebuilt the carb over the winter. car runs great, choke works and all. now the problem, and it doesn't do this all of the time, but on a couple of occasions when we shut off the engine fuel leaks out from the carb. and runs down the manifold and into the venturi of the carb. the first time it happened i took out the needle & seat expecting to find a piece of dirt or somthing. found nothing, put it back together and it was fine (new needle & seat from rebuild kit) seemed to be good for a couple of weeks, then yesterday i was showing the car to a friend and there it was leaking again. i drove it home and it ran fine. checked it again when i got home, no leak. took out the needle & seat again just to check it and found nothing again. it seems like when this does happen that there is pressure in the fuel line even though it's not running, and it pushes most of the fuel out of the fuel filter.
i'm thinking maybe a bad float? not putting enough pressure on the needle? i will pill the carb this weak end & check it out.
any other suggestions or help would be great.
64 225 carter carb 1barrel
thanks, lou
thanks, lou
