Left turn signal twice as fast
robjkc
Springfield, MO
I was curious if anyone might know why my left turn signal flashes twice as fast as my right on my 64 Dart.
I've got a new turn signal switch that I plan on putting in at some point to fix my broken cam. Maybe I should just wait and see if the new switch fixes this issue.
Thanks,
Robert
usually when a turn signal bulb flashes faster then the other one of the bulbs is out check front and rear to see if its flashing,,,the faster side will be the side with a bulb not working
Yeah, all my turn signal lights are working. I may try to inspect the bulbs to see if there is any corrosion on them or maybe just replace them all. Thanks!
Check all your grounds.
Could possibly have a wrong bulb in there somewhere too.
x2
i know some bulbs will fit just fine..but they where never intended to be used in the vehicle...my 66 barracuda can fit the 1157 bulbs but its not correct. they are the 1xxx (cant remember?) a bit smaller (physically) and possibly resistance difference.
aloha Mike
From Sylvania's website.
Print out the list and find them at your nearest retailer.
Certain bulbs are available for sale at the SYLVANIA Online Store. New bulbs will be online for purchase in the coming weeks.
Stay informed about new products from SYLVANIA. Sign up with one of our newsletters and let us help you with your needs.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
1964 DODGE Dart
High & low beam headlamp
H6024
H6024ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H6024XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H6024CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
1034
1034LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
1034
Rear turn signal
1034
Tail light
1034
Stop light
1034
License plate
67
67LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
1073
1073LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Ash tray
1445
1445LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Glove box
1891
1891LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Map light
1004
1004LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
1004
Step/Courtesy light
1004
Trunk/Cargo area
1003
1003LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Under hood light
1003
Instrument-general
52
53X
57
57LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
90
90LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Brake warning
57
90
Automatic transmission indicator
53X
Directional signal indicator
52
90
Ignition switch
57
Radio dial
1892
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Flasher switches are triggered by load. When there isn't enough load on the circuit they don't flash, whis is why a burned out bulb on one side will usually cause the signals on that side of the car to flash slowly or not at all. Converesely, if you have too great a load on 1 side, such as a bulb of higher wattage, that side may flash faster.
Look for something causing a greater load, mis-matched bulbs, corroded connections, etc.
Flashers operate on resistance. When one bulb is blown that side will flash slowly or not at all ( most common ). When the are more bulbs ( like a trailer hooked up ) resistance goes down , flasher operates faster. Rapid flashing will kill the average flasher. Only an equal system will provide equal flash rate.
Now your question is... Is one side too fast or is the other side too slow. I cant answer that from here. Hope this helps
First off thanks for all the responses and helpful information! The number of people willing to share their knowledge on this site is overwhelming. I think I'll be a Mopar guy from here on out.
As far as my problem, I just checked my front lamps tonight and you all were right. I had a 1157 in one socket (fast side) and 1034 in the other. I replaced both of them with new 1034 wagners (all they had at O'Reillys).
The seemed to make all the difference. Both sides now blink at about the same rate now. I haven't checked the back yet but will do so soon.
Thanks again!
Thats what I like to call ALOHA!
FABO should stand for best mopar helping people ever....ok doesn't fit...but...yep ROBJKC....I'm with you...amazing people here...
aloha mike
swap bulbs, if it does it fast on other side its bulbs, check wattages too then go for earths, get a bit of wire,connect to a good ground and tap on bodies of indicators, if slows its a ground problem.sorry if sounds crude method, im a sparky and these simple tests the best and easiest.:cheers: ps, get matching wattage bulbs to the ones that are working right,
