Less than 12V on VR Input w/pics
Fittrjoe
Spokane
67 Barracuda with New Alternator but slightly overcharging 14.5-15.1
I think I know why.
VR input is 11.08 when Batt is 12.56 , key on.
Key off is .32
Added a few nice grounds from Batt to fender and Alt to fender recently per advice of a friend FYI
Shouldn’t Input wire on VR be same as Batt?
What’s the fix?
VR input is 11.8 when Batt is 12.56 ,
11.08 vs 12.56 is a 1.5v Voltage drop
Is that with the engine running or off?
That's a lot.
Check...
The bulkhead connectors are clean and tight.
The ignition switch connectors and terminals are clean and tight.
You should check it with the engine running
I have written hundreds on this. Maybe more. Voltage drop in the harness, terminals/ connectors and switch, and sometimes the ground circuit
To check, turn key to "run" engine stopped. Stab one probe into the top of the POS battery post and the other as close to the VR IGN terminal as you can get. Or connect to the "key" side of the ballast resistor. You are hoping for a very low reading, the lower the better. anything over about .3V (3/10 of 1 volt) you need to chase it down. Culprits are any connections, the bulkhead connector terminals for the big red and big black ammeter circuit, and the dark blue "Ign1" "run" line. Also the ignition switch connector and the switch contacts themselves
One way around that is to electrically cut the "IGN1" run wire where it comes into the engine bay, use the firewall end to trigger a relay, feed the relay off the starter relay "big stud" and run the engine bay end of the run wire to the switched contact.
GROUND: Make this test with engine running fast to simulate low/ medium cruise RPM, and first with all accessories off, and again with them on, heater, lights, etc
Stab one probe of you meter into the top of the NEG battery post, and the other hard into the mounting flange of the VR. Again, the lower, the better, zero is perfect
Whatever drop you measure in the harness from the battery + to the VR IGN (EG 1.5) will be ADDED to a properly working VR, AKA 13.8 + 1.5 the battery will see 15.3
Whatever you measure in the ground test will be added to THAT
That's a lot.
Check...
Off/ ignition on
Thanks for this detailed reply sir
That's a lot.
Check...
Thanks for these tips
Checked with engine running and although a moving target … averaging about the same as off - 1.5v differential
That's a lot.
Check...
Sorry to be a newbie but ignition switch as in inside the vehicle where the key inserts
Thanks !
I suspect Dana's point was that there should be no voltage drop with the key on or off unless something besides the ignition and field are drawing power. Voltage drop only occurs when current meets resistance. Key on with a normal ignition and field should draw no more than 5 amps. The ammeter will show whether the battery is supplying 0 amps or 5 amps or more.
Part of my thinking was with a point ignition, the engine can stop with the points closed or open. If closed there will be more current through the bulkhead connectors possibly creating more voltage drop than when the engine is running.
With an electronic ignition that might not be the case
