lightweight master cylinder
dodge71demon
Indiana
Can you still buy the Mopar Performance lightweight master cylinder?Has anyone used this on an a body manual disc/drum
i just bought mine from reillymotorsports and im running discs up front drums out back. works/look great. i just wish i didn't spill any brake fluid on the inside fender. :(
Do you need adjustable pushrod or will the stock length one work with the diplomat/ARengineering adapter?
A manual brake pushrod from the same make and model works with the aluminum MC and the adapter plate. There are several different pushrod lengths from the factory depending on the vehicle.
