stroker_valiant
When you shut the car off, have you ever experience engine "run on",
where i whheezes and turns backwards?
No run-on, or deiseling after shutoff.
I have a spare 904 I can gut so that might make the job easier.
when you line bore the block it still SHOULD be centered...
i would look at the thrust of the crank...
you could throw a manual bell on it and just use that to measure to see if it "wobbles"...
could the flex plate be on backwards causing it to shove the converter into the pump?
N, I believe the line bore moves the centerline of the crank toward the deck. Thats why good timing chains can be had undersized for line bored motors. Not much, but it does move it. Offset bushings would solve it. Hamburger makes offsets that rotate off center so you can dial them in. Sometimes necessary for manual trans motors.
Glad to hear you found the problem without having to dissassemble your tranny or your spare for that matter.:laughing:I had cracked my high dollar Coan 8 inch 4500 convertor and had to have a new snout re-welded on.No problems with my trans since.:toothy7:Finally my car is whole again!!!
It has been a long three months now, funds were limited, but the trans is back in the car and performing flawlessly. The problem ended up that the hub on the convertor was welded off center by .20 or .28 thou. off center. (And no I didnt feel any vibrations, solid motor mounts on the car). I have had the car going for about two days now, have made several hard, winding out full throttle pulls on the highway, and also dropped to second gear multiple times from about 50 mph, and spun the motor to about 5500 with no problems. I had PTC do the work that J&W racing tried two different times, and PTC did a wonderful job. The welds look like a machine welded them, and the convertor has a lot less weight for the balance now. Just thought Id let all yall know.
You are right, 5500 is not that high. But it was doing its cracking way before that when stuff wasnt right.
At the time I had an unbalanced driveshaft causing all kinds of driveline issues.I snapped spring perches off,also cracked the bajeebles out of my trans housing,which I believe caused a chain reaction to the torque convertor.:violent1:Got it all fixed up now.Hmmm, I got around 5,000 miles on my TCI streetfighter converter which did not fit in the crank all the way ? We had to grind the snout to fit--it went in but not far enough. Had no problems with it and TCI is not liked on here too much, maybe I got lucky ?
I also put new rubber motor mounts on the 340 at the time and buzz it to 6,500 a few times and over 6,000 all of the time. It spins over 4,000 on the freeways with 3.91 gears and goes 75 to 80 once on the freeway
.28 is over a 1/4 inch, could well been the problem
