What is the advantage of oiling through the pushrods?5/16 ball
7/16 threads
These puppies arent cheap!
Also, Alan Lockheed, creator of the Engine Expert engine simulation program, reported one client changing to a much lower ratio exhaust rocker in his Mopar Modified at the track at Alan's suggestion and experiencing such a gain that he had to change gearing to get off the rev-limiter.
Food for thought... View attachment 1715460335 Mad bill 2018
any recommendation on rocker ratios- but you have expensive ones already
Mike should have a handle on the timing around BDC as he considers stroke and rod length as well as your flow
I'd take a sponsor for a hamburger,Right now mike has not said if 1.6 would help on the intake or both or not
I always recommend run what you have and get a baseline
try advancing the cam, retarding the cam and find out what your ride likes at the track
Need a sponsor for the springs or lifters or cam?
Okay...here's the cam suggestion for my dirt motor from Mike Jones... Just remember the 294 CFM intake flow and a 7200 rpm limit.
I have to admit I'm not seeing enough lift here BUT Mike's cams are hard to beat. His stuff kicks *** and I'm so impressed that I am having a hard time deciding on what to run.
Waiting for Howards reply... may never come!
Here's what I recommend.
Cam# Chr360, M74375-77370-106
250/255 @.050"
.375"/.370" Lobe Lift
106 LSA
Price: $263.32
Lifter# J904MH
.904" Mech F.T. lifter w/.024" oiling hole in lifter face
Price: $168.36
If you want to run a beehive, I recommend the PAC 1235
PAC-1235 Hemi 5.7L, 6.1L 0.600 Lift Drop-In Ovate Wire Beehive - 1200 Series Beehive - Valve Springs - Products | PAC Racing Springs
My reasoning for trying a beehive spring...
I'm not going to oil thru the pushrods.... Shaft oiling only and I'll tube the block, drill the oil galleries as needed, etc.Ok so I am curious how you intend to run your oiling system on this motor. Obviously with a lifter with a .024 hole and pushrod oiling, you are not cutting oil to the tappets. Can you elaborate on your total oiling plan for this motor. I know this is a valve train thread, but they are interrelated.
no dumbell
pr oiling in the lifter?
Dont know about Krooser but I am going to run oil thru pushrods to ensure adequate tip oiling . I will still be oiling the shafts/rockers via the block . Ryan drilled oil feeds my W2 race heads .
That Howards grind is closer to what I would have expected for your heads .
Something most people don’t connect the dots with very well is the fact that “most” cam lobe designers........ are not engine builders or head porters.
They understand the math to develop a cam lobe, but don’t necessarily understand what specifc lobe characteristics that certain engine families respond positively too.
Knowing how to design a cam lobe doesn’t automatically qualify you as an expert in knowing how to make power.
If everything could be pre-tested to perfection with 100% accuracy in simulation, there would be no need to physically test anything.
We’re not there yet.
