I guess I’m just lost.
You bought the complete blown up engine before racing it in 1993?
Here's the story.
Jerry D. built a WISSOTA modified in 1993 for the '94 season. He was an experienced racer but this was a new locally built Cobra chassis. He had Baxter Engines in Eau Claire, WI build this 360. Had Ross pistons, 340 rods, Crower valve train (Ti retainers and locks and springs) with Manley stainless valves (3/8). Billet Mopar Performance crank. Nicely ported W-2 econo heads with Mopar adj. rockers. M-1 intake. 780 methanol carb. MSD dizzy. Made 575 HP. Cost $15K.
Jerry was pretty conservative with his stuff... he kept the rev's down to save the motor. Ran the car on the big clay half mile at Marshfield, WI. Ran about 9-10 nights for two seasons.
Following the '95 racing season the track owner paved the speedway. Jerry didn't like pavement racing. Jerry sold his car and put the engine under his work bench hoping to use it in a future hot rod project.
Fast forward to 2004. Jerry's "friend" also ran Mopar stuff and he needed an engine to run the late season specials. His engine was toast so Jerry loaned this engine to his friend.
First night the engine ate the camshaft. It went back to the engine shop to be freshened. The next race the temp's were cold. The guy didn't warm the engine before hitting the track. He said he felt it tightening up but thought it was an ignition issue. Then it seized up on the #1/#8 rod journal...broke three pistons and damaged four rods.
Jerry took it back and put it back under the bench. He decided to clean out his shop three years ago and I answered his ad on Craig's List. I bought it when I saw it... had to make payments until I could pay it off. Drug it home two months later. Been slowly getting it back together since.
When I took it apart I found the oil to be the stickiest, thickest stuff I had ever seen. Jerry ran 10W30 Valvoline racing oil. This must have been 50w with three cans of STP added. There were droplets of oil hanging on the rod bolts for 13 years that had not dripped off the rods. Thick.
I took the block back to the original builder to have it repaired. I did have my LOCAL shop redo the cranks.
The crank's has been welded and repaired. The block has been sleeved and decked and is in the shop waiting for RaceTec to ship the new pistons so it can be bored to +.040 and be skim decked. I bought eight 340 rods from a FABO member and had them resized and get the good ARP bolts. The heads I'm slowly working on...likely I'll replace the valve guides with 11/32 or 5/16 pieces and buy new valves. The valve job looks like new so I'll just lap in the new valves.
I got a new set of T&D rockers with the engine and I plan on using those.
That's where we are at.
