[WANTED] Looking for 360 engine, 71 -74 casting number 3418496
I might have one.
How complete do you want it?
Long block, short block, just the block itself?
I have several cores of many years, probably 10 or so.
I also have several 318s if that is an option to you as well.
But the shipping would be a killer. (just so you're aware of this)..........
If you could check that would be appreciated...let me know what you have....I'm open to all options
I'll check for you when i get back to my property in B.C., it might be a few months if you can wait. (snow covering everything)...........
Do you want just the block, or what level of completeness do you want it?
I don't usually do this but I changed your thread to a wanted thread. You should get more response there.
Darnut, Complete 360 would be best, however long or shirt would work too...I am in no rush so a few months would be fine. I am from Victoria so shipping to there will probably be the plan...Just let me know what you have, thx.
Toolmanmike, thank you for the thread change this is all new to me....when I owned a 1970 Duster in high school you just knew a guy who knew a guy....no emails or threads just a telephone call to get parts and pieces ...so thx Shayne
:thumbsup: no problem. Hope you find what you need.
Shipping from US would be the same whether it is a core or a built motor. Something to consider. My advice is if you buy a core and are having it shipped spend the extra and have the seller take it to a machine shop first. No you aren’t going to get a motor for $300 but you ARE going to get something you know you can build. I have bought a lot of cores that end up having scrap blocks or heads and end up becoming parts motors for something else. They are out of their homes for a reason. Same goes for the ones that were running when parked....running yes....but that knock though? Lol
Are you in Victoria BC. or Toronto ? I have a 71 Block at a buddies house here in Boise but wiuld have to have him check the numbers.
Boise is driving distance from BC...
I will see the next time i'm there.
its just an extra block I have sitting at a friends house.
I do have a nice 360 crank ,Rods and pistons that came out of a low mile Motorhome block that I used for my stroker.
But if all this stuff needs to be shipped to Toronto it seems cost prohibitive.
Thx for the follow up ...any idea what the block and crank might weigh...is the crank cast or forged? let me do some digging into shipping and I'll get back to you. Thx
Cast crank...no factory 360 cranks that I know of.
Weight has to be around 150#s
I would want 300$ for the block.
Zip here is 83714
Early 360s are said to be essentially 340 castings only bored to 4.0 and larger main journals.
Thick cylinder walls...
