Bookmaker
I have a 1974 Duster survivor w/318 auto. I'm trying to keep it stock-looking for the shows, but at the same time I'm wanting to tune it as best as possible for better performance. I will be changing out the 2.45:1 gearing in the 8.25 rear end for 3.21:1 with track-lok. That should make it a bit more fun.
With regard to the engine, I've bypassed the OSAC so that port vacuum goes directly to the distributor. For the distributor itself I have a set of lighter springs from Mopar.
Question 1: Where should I set the base timing, and should I use the FBO limiter plate so that I can set initial timing higher? (Factory timing spec is TDC)
At the end of the season this year I plan to upgrade the silent timing chain with a double-roller chain and magnum tensioner. If I am into it that far, I might as well upgrade the cam too. I will probably upgrade to dual exhaust also as the original Y-pipe is not going to last much longer.
Question 2: Would a stock 340 cam help this engine much given that I will be keeping the stock 2BBL carb on it?
Thanks.
Thanks.
