dibbons
First foto (cylinder #8) has a right angle at the bottom of the cylinder. The other cylinders (foto #2) have a chamfer/bevel.
Absolutely. The block is bored and there is a ledge left for the sleeve to stop against.I'd like to see the deck but that looks like a OE cut to me and not a sleeve.
If the sleeve is set correctly, you can't tell.
Sleeve in Number 8 next to NO sleeve in No. 6....
also near the bottom of the cylinder you can see a cut where the sleeve ends...
