jhdeval
Ok I am scratching my head and totally lost. I have a no spark situation on my 65 Barracuda with a slant six. I have checked replaced the ballast resistor because my voltage was around 6-7 volts I now have a solid 9 volts at the ignition coil. The ignition coil is also brand new. I had replaced it with one from my local parts store. I get a little under 1 ohm on the primary and around 11000 (11k) on the secondary coil. This is within specs for the coil and according to my local parts store the correct replacement. I have tried grounding the threads of a spark plug both after the ditributor and right off the coil tower to no avail. I simply don't know where else to go. Can anyone help direct me? Maybe my coil is outside specs for the ballast resistor?
