I've been running my 340 for about 200 miles and she's been doing real good. I had had a privious oil pressure issue and had solved it by replacing the oil pump, Now, all of a sudden (after a jack rabbit start) the oil pressue went way low 5-10psi, and the valvetrain is not oiling properly , rattling. We dropped the pan and the oil pump seems good, but in looking up into the cam journals it looks as though one of the cam bearings is out of the journal about 1/16". WE plan to replace the oil pump again just for peace of mind but also have these questions:
1. Does this sound like an oil pump problem, i.e pressure relief valve?
2. Is it possible to spin a cam bearing to lose oil pressure and what in the world would cause this? and if so how do you fix it?
3.any other thoughts?
