RGAZ
Diehard
Ok so against my better judgement I picked up a disassembled 71 440 from a local guy. He appeared to be organized but I am guessing not now.
So I am assembling the bottom end after cleaning honing etc. block is marked underside and the old bearings he left behind confirm 0.001 underside. I picked up some king bearings and when I torque to spec they lock the crank. So I whip out the Plastigage and there is like no clearance. So I try a different piston position and get the same. I put in the old bearings and same result (my uh oh moment).
So now I think he may have mixed up the caps. That or the rods are warped. Here come the questions:
Is there a way to re-match the caps?
Keeping this low buck, should I get some cheap rods and move on? What are the cheapest option?
Or do I need to bail and take it to a machine shop and blow my budget?
Thoughts?
RGAZ
Thoughts?
RGAZ
