mrose
Active Member
So what happens when you remove the blue and green wires from regulator and connect them together ? That would give full field, to test alternator, the alternator post voltage should increase. Do not rev engine, the voltage and current may go too high. Your battery is very low on charge, the voltage may tale a few minutes to increase.
I assume that if I get the higher voltage 15V + or - that will show the "new" VR is bad? or could it be something else?
OK I will give it a shot tomorrow and let you know what happens. Thank You
