Lower rad hose
brian6pac
Legandary Member
Legendary Member
N.E.Ohio
I found this hose at O'Reillys auto parts for my run stand. BB w/left side inlet and right side radiator lower hose.
That crazy! Funny as heck!
Good find and post!
Does it have a spring inside?
No spring but I think the only time you need one is when there's no pressure in the system, if it has a good cap it should build pressure as it heats up. Any way it is a thick stiff hose, I don't see it being a problem.
How about one or two shots of the run stand. :)
I'm working on a permanent one soon but all the ones I have made have doubled as delivery stands, 1" angle iron is really all you need to run a motor on and break in a cam.
