BWDart
I took the old pickup and cut the lines off, used a second pickup for a pattern and bent the 3/8 line and drilled out the sending unit and JB welded the line in. It helps having a second pickup to use. I had a new screen so I drilled it out to fit the 3/8. Quite a difference in the 2.
