Steady driver
Active Member
Can a duel point be converted to electronic ?
And what exactly is wrong with running a dual point? A good one will be true past 10,000 rpm
Dual points are not difficult to set up. Hook up you dwell meter and place a match book between the secondary set of points. Set dwell to 26 degrees. Remove matchbook and place in the primary points. Set dwell on the secondary to 26 degrees. Remove the match book and put your cap and rotor back on. Takes only a couple minutes.
With a. Properly set up dual point there is little to no horsepower difference when compared to electronic. Electronic ignition has its advantage with long term less maintenance.
That's true if it's a conventional 8 point cam [V8] Those damned Mallory "rev pol" 4 lobe designs are a PITA
Actually the electronics are slower. It's called slew rate. Since its predictible, it can be compensated for in the curve if you know its there, or in a few over the counter products its suppsedly done in the electronics.
Points are a certainly harder to setup, especially duals points in the back of the engine. And they do wear out over time. As far as providing better ET or MPH, if everything is set up good, power is really not to be had in the ignition. Some fancy stuff can help in compromised situations or in high HP race engines.
That's the key, and the point of my post (#10). Fair amount of details in the links, especially the last, which should help anyone interested. I'll add more when I get back on the distributor machine.In the end, the tuning of the advance curve compensates.
