Mexican Hat
Pentarockstar
usa
Will the "Mexican Hat" or "Nipple" Rallye wheel center caps fit on 74 Dart with disc brakes?
Are you talking about Rallye wheels or steelies? The early "cone" caps interchange with later "acorn" center caps, as long as they're both 4.5" caps. Factory center caps came in both bolt patterns, small for 72 and earlier A with disc, big for B-E bodies.
Thanks for the reply. I am looking to see if the BBP "cone" center caps will work with BBP Rallys with factory disc brakes.
They should as they have nothing to do with rotor clearance. IIRC the depth of the bowl for those is unchanged.
Not that kinda hat Heywodya! LoL
My concern is fitting a disc brake hub inside a cone rally cap. At this point I guess it will work, don't care for the robot head style
