360 heads are open chambers. You cannot get any Squish/Quench out of that combination, with flat tops; which means, that the engine will be somewhat pressure limited, to prevent detonation.
Pressure makes heat, makes torque, which, times rpm, equals power.
IE, lack of pressure is lack of power; especially at lower rpms.
To "get some bottom end back", you will need;
A) a higher stall convertor, so the engine doesn't have to operate in the marshmallow zone, and
B) higher ratio rear gears, so the engine can spool up into the power zone and sorta hover in the powerband, after the shifts.
Neither of those are cheap.
C) IMHO, if you want to keep those heads, you'll need to get some specialty-pistons with machinable Q-pads, cuz without Quench,typically yur engine pressure will be limited due to detonation.
Here's the deal;
Early 340s were rated at 10.5Scr.
They weren't that.
At best maybe 9.8, and they had forged pistons/forged cranks, and a pressure bleeding camshaft, which all worked together to try to prevent detonation, even with best leaded gasoline of the day.
If you copy that deal with; hypers, a cast crank, a tight LSA street-cam, and todays gas ............. you could be in for a world of hurt.
Yur plan is pretty good, but I'll never run open chambers again. And if you machine yours, you always take a chance that the machine shop will get all the angles right. I would trim some fat off your parts list and go straight for some closed chamber heads, and since I have had such a great experience with alloys at up to 195psi/still on 87E10 pump gas, how can I not recommend them...........
