Mopar 273 Commando projet, Mopar Magnum valves, Stroker sleeper, Mopar 920 heads
I’m not really understanding the rationale of using small port heads on a stroker looking to turn some rpm.
I get the sleeper thing, but after it’s all together and in the car……… how much different externally do 340/360 heads look?
But…….. I guess I don’t have to understand it.
Guess that's what the customer wants, sounds like a mutt of an engine 273 heads, 340 intake, 318 block, with a stroker crank guessing probably 3.58 maybe 4 he won't say :) Sound like they want it to spin at least 6,000 rpm.
He said the owner wants it to look like a stock 273, but the intake already screws that up, but ya makes no sense to use 273 heads when 340/360 heads look the same.
Since in my 20's, a long time ago, I was always suspicious of something that ran better than it should. So, how many people do you think you are fooling? I don't lie about such things, it's easier to remember the truth. But, to each his own.
only a anorak would spot the difference on cast factory heads. why not use 340/360 units?
something like an LD4B or holley street dom with the numbers shaved would probably pass the glancing eye test, especially if everything was painted up and dressed like a commando.
Probably make decent low end (350-392 Cid) and if it can be made to breath enough should also make ok hp, probably be expensive hp but as long the owner ain't thinking anything too crazy hp wise he'll probably be somewhat happy.
I might agree with you if I had a clue what an anorak is.
If they're using a 3.58" stroke and these '302 variants the peak torque will be absolutely abysmal at about 1lb/ci. I would never go down this path ever again even if paid mega$$$$. Complete and utter underperformer the one I built turned out to be. J.Rob
lol. Sometimes money doesn’t make these builds worth doing.
When I was still doing “full porting” of iron heads, I’d have been willing to work over a set of heads like that…….but the level of R&D they would have gotten would be a fraction of what CS will do.
They would have gotten a basic clean up of the entire port……..and whatever they flowed after that, “iiwii”.
To the best of my recollection, I’ve only ever had one 920 head on my bench.
It was when I got my first bench in 1992.
I was testing various heads for a couple of circle track 318’s I was building.
The guys I was doing the engines for had blown one of the engines built by another shop up, and that engine had 920’s.
One was busted, the other was salvageable, but they couldn’t locate another one.
I don’t remember the actual numbers at all, but I seem to think the 920’s were better than the generic 318 open chamber heads, and the 302’s as well.
There was a typo in the rules that made 360 heads legal.
The owner had bought into the MP 302 head propaganda, and that’s what they were running on their “good” motor.
The flow bench said the 360 heads were way better, so I prepped a set and we did a back to back dyno test between the 302’s vs the 596’s.
596’s for the win by about 40hp.
Using a piece of **** 188 intake valve and trying not to hit any water, 233 CFM is what I got out of them on the intake side
