Could you be more specific as to 'performance'?Got a Mopar 400 block bored 0.060.
Any good performance recipes out there ?
Thanks
450hp is good enoughCould you be more specific as to 'performance'?
Did you want to keep the engines stock crank and the cubic inch displacement at 400 minus what ever the overbore gives you?Got a Mopar 400 block bored 0.060.
Thanks
Street/Strip and no budget.Now, what is the engine purpose and budget? Then these folks can get down to some designing.
Not for free. Of no budget I mean like could spend as much as I need too450 HP for free?
This will do it. So will the one IQ52 posted.4.380 bore
4.250 stroke
6.535 rod
Trick Flow 240 new out of box
Trick Flow intake
Solid roller
10.5 compression
72 Dart
Hopefully going to put it together over the winter ! Will see how things go !
$$$$$$, the man said budget, if anyThis will do it. So will the one IQ52 posted.
Not sure where you are getting the word budget at ! You seem to be fixated on that word ! Op says specifically no budget in post 11 ! And doesn’t say anything about a budget in post 1 !!! If I missed it somewhere else in the thread , I apologize now ! IQ52 seems to have the ticket for this op’s build though ! Free is a good thing these days ! For sure nothing wrong with your budget build you posted also… It’s looks like your build could be 500 hp possibility ! Even better !$$$$$$, the man said budget, if any
3K.How much money does one put into porting heads like those?
Yeah and that was 11 years ago.
Not the first or last time I'm confused lolNot sure where you are getting the word budget at ! You seem to be fixated on that word ! Op says specifically no budget in post 11 ! And doesn’t say anything about a budget in post 1 !!! If I missed it somewhere else in the thread , I apologize now ! IQ52 seems to have the ticket for this op’s build though ! Free is a good thing these days ! For sure nothing wrong with your budget build you posted also… It’s looks like your build could be 500 hp possibility ! Even better !
