mopar performance valve covers?
74360duster
JEREMY
JAMESTOWN,MO
will the black wrinkle finish mopar performance valve covers clear roller rocker? i would like to run a set on my 408 im building. I am running comp magnum rockers and shafts. I hope someone can help me out with this question I would hate to order them and then find out they will not clear..
thanks
I got MP cast aluminum valve covers on J heads...Edelbrock heads...and Mopar W2 heads...all with roller rockers....So...Yes..they clear.
you will probably have to grind the lip on the top rail of the valve cover where they go over the intake manifold...
Thanks for the response. I didn't want to buy a set till I knew yes or know if they would fit,its either them or some aluminum fabric stated ones. And I think with my aluminum hears it would look better with the black ones than too much aluminum going other route.
