Motor Mount suggestions 69 340 Swinger
RS23VOA
VA
Guys
I need to buy motor mounts. I'm leery of the $3 Rock Auto mounts but don't want to spend $200 for Schumaker mounts. What's everyone using? It is a basically stock 340 and A/T
Thanks
Do you need just the rubber part or the metal brackets that bolt to the engine block???
Just the rubber with the stud on each side .
Thanks. I was looking at that at the Rock.
If summit sells them for $4, then the ones at rock should be similar... I was just price comparing and showing you the difference between the "fat" one and the regular one...
Thanks. I was just leery of a $3 mount. I've broken plenty.
