the bolt holes are not perfectly square. it will only bolt one way. Just use a paint marker and mark the converter and flexplate so you will get it right the first time on assembly.
Thank you for taking the time to help me I understand now fully.
Great inputs. I did all of this already.plastic bag over tail shaft with tight rubber bands.I do the engine/trans together all the time. No biggy, just take your time.
Couple of things to do beforehand-
-Pull the driveshaft, wrap the trans output in plastic and secure it in place with a couple winds of duct tape. Or use a spare yoke if you have one. Otherwise you'll end up with a gallon of ATF on the floor under your car.
-Pull the distributor. Clearance to the firewall can be minimal, and twisting/tipping the engine can bust your distributor if you're not careful.
-Don't forget to drop the exhaust. At the manifolds is best, but can be a pain if the bolts are rusty- and they always are.
With the hood open, loosen all four hood bolts.Only need to remove the hood and that I can’t do myself.
I pull them with the hood on.... but I bolt a chain from the front drivers head to the passenger back 2 intake bolts keeping the slack only about 3" above the intake.Great inputs. I did all of this already.plastic bag over tail shaft with tight rubber bands.
Only need to remove the hood and that I can’t do myself. Headers were taken out last night. That was a pita on the driver side.
I am leaning toward pulling just the motor and then if I am able install as a unit trans/engine.
Not noted but assuming floor jack would need to be north south to roll with movement.It will want to tilt as you lift it out of the car. I just get the motor mounts off the K-frame, then I slide the engine/tranny ahead. That's when I use one of those small 24.99 floor jacks on wheels to help the tail shaft over the crossmember. Don't need a lot of pressure or anything, just get it to clear.
yeah... once the 2 bolts are removed from the mount to tranny, it will just slide right on over. Just giving it a little support so it doesn't do something stupid like tare the rear seal or something. I've never had a issueNot noted but assuming floor jack would need to be north south to roll with movement.
Just thinking out loud if I'm in similar boat.
Hope the OP reads this.yeah... once the 2 bolts are removed from the mount to tranny, it will just slide right on over. Just giving it a little support so it doesn't do something stupid like tare the rear seal or something. I've never had a issue
Yeah, I've pulled it tipping the jack over before... lol. None of this is critical. Eyeball it and it makes common sense....Hope the OP reads this.
Jack needs to be oriented to roll forward or backward supporting transmission as I understand it pulling engine and transmission together.
Or you just roll the car backwards, which is usually easier.Hope the OP reads this.
I still support the transmission tailshaft just so it doesn't scrape it's way over, and some seals have the rubber boot and that can get torn.Or you just roll the car backwards, which is usually easier.
Especially if you're using a chainfall or winch instead of a cherrypicker.
Right, but you don't have to worry about orienting the floor jack, since it can stay relatively stationary.I still support the transmission tailshaft just so it doesn't scrape it's way over, and some seals have the rubber boot and that can get torn.
Separately since I was doing it myself. I probably could’ve done both at the same time through the top, but I didn’t want to chance it. So the transmission came out the bottom. The four top bolts at the transmission are a pain in the ***, but not too bad once I figured out how to make an extension on a box end.So did you pull together or seperated
