Motorhome 318
lodaddy
Aurora
Looking to get a 318 out of a RV (71 winnabago). Looking at the timing chain cover I notice the timing marks are on the passenger side. Anything special to do when swapping out the covers to set timing marks since the ones one my current 318 are on the drivers side?
Use the balancer from the MH, or get another and make a mark with a hack saw and some yellow paint. Not sure if they sell the balancer with the TM on the other side still.
Your swapping the 318 from the winabago to your car, right?
If so,... what wrong with using you timing cover and harmonic ballancer off your original eng?
the key way will be in the same place, on the crank on both motors!
If that'll work that'll be great. I wasn't sure since the timing indicator lines up on the passenger side of the timing cover on the RV motor. If it is as simple as the I'll be in business. thxs
to be more spsecific the water inlet from the MH water pump to the water inlet under the carb. do I just plug it off? thxs
