HemiTM
I am in the process of putting a PerTronix 1381-A on my 66 Newport. I would like to bypass the ballast resistor and use a PerTronix 40511 3.0 ohm coil. I have a MSD 8202 which has a primary resistance of 0.7 ohms and a secondary resistance of 4.5k ohms. Not being much of a electrical guru, I am not sure if MSD will work properly or if I should purchase the new PerTronix.
What do you think?
What do you think?
