Muffler
dodgedart1968
Amston, CT
The previous owner installed a noisy Thrush muffler on my '68 Dart 225. What Walker muffler would be a suitable quiet replacement?
Can you tell if it is OEM sized front and tailpipes? I can look up the right one if I knew...
Rumblefish, as usual, is right on. The one suggested is 21.5" overall length as is the OEM one. And inlet and outlet bushing sizes are right and it is cheap! :)
Thanks Tom. I wasn’t 100% thinking that was it but it seemed to make sense and about fit right.
Thx gents. The prior owner did such a poor job of installation that the pipes are loose in the hangers and the clamps allow the pipes/muffler to rotate! I'm soaking the exhaust manifold bolts in penetrate, so the whole assembly should be easy to remove. The exhaust pipe and tailpipe are rust-free, so the job should be low-cost.
