My 1972 F7 Dart Swinger
Sorted out a weird issue with the blower motor. I had all 3 fan speeds with the air conditioning on but with the heat on, I only had low fan speed. I took the glove box out to diagnose, and this is what I found.
I really like the simple fixes! I must’ve bumped it when I was installing the dash and knocked the connector off.
I got the drivers door glass put in, but I’m struggling with the adjustment to get a good seal. Took a pause from that for my sanity decided to apply my stripe.
I've always wanted a bumble-bee stripe to match my vinyl top. Where did you get those?
The red against the stripe has always been my only concern.
I got mine from Phoenix Graphics. They sent me all the metallic gray/silver materials they had (6 or 7 samples?), I picked one out and they made them using the factory stripe template on hand.
Got the carpet all put in over the weekend. Front/Center buckles were bolted in just to hold the carpet while I worked. Not too much left to do on the this interior. Still need to adjust the windows before I can put the vapor barrier in and install the door panels. Really trying to avoid that for as long as possible
Today I got the overfill valve issue sorted out
These first showed up on 72 model year along with the charcoal canister. The OE valve was inserted into the top of the vent line in the engine bay then rubber line connected it to the canister. No one seems to make a valve that small that serves all the same functions. This is a tank vent from a diesel truck that allows 2-way vapor flow. It shuts if liquid fuel comes in from the tank and also shuts in the event of a roll-over. It fit nicely at the top of the vapor line!
For reference, here is what the factory overfill valve looked like
The tubing was expanded and the valve inserted then the tubing was closed around the end.
Got my Lloyd floor mats put in but didn’t get a picture. They look pretty sweet. Black with DART in green stitching.
Still messing around with the side windows trying to get them aligned and sealed good….
Test fitted a design tweak of these hood insulation trim pieces. These slip into place in the hood scoop rubber seals and dress up the hole in the insulation.
Got the passenger side door and quarter trim panels in. Still some window alignment on the driver side door to fine tune before I can button that side up.
Actually drove her to the gas station today and took a short drive around the lake. Felt pretty surreal to be on the road with that car after all this time.
Wiper arms installed!
I got the driver window all set and sealing good so I was able to finish the door panel and rear seat trim panel. I got the door pulls and window handles installed.
The paint and Dart are so much nicer than factory. Who would ever guess the love and attention we give these cars. The 64 Corvette is detailed 10x’s the level of a production car. Inside the engine compartment fender wells, under the hood, etc is as nice as the exterior. On an original it was a shade of black. When I took my Dart by my painter today, I mentioned all I really wanted was a driver and had not expected to go this far with the car. Both of them said it’s not in your nature and laughed.
Very nice! What was the timeline your painter gave you?
To the public he always quotes 18 months for old cars non insurance work. They always say put me down as they can’t find anyone remotely interested.
For me he usually fits me in. The plan is the fix the one quarter I am worried about. Paint my engine compartment and trunk. Then drop the motor. Then late fall spray it when I have some money.
