Hi everyone
Just thought I would post some pics of my 70 duster project. It started out as a 318 car that I bought so i could put the blown motor that I had from an unfinished and sold pro street project. I swapped the disc brake k frame under it and moved the leaf springs in 3 inches and built mini tubs for it. It has 15x12's on N50-15's tucked under. I have,but have not installed the following...8 or 10 point cage,I bought it so long ago I really don't remember
Chassisworks ladder bars and coil over springs for the rear
I changed the deep sump pan back to a stock pan as I was tired of hitting it because it hung down so low. I also have to weld the back of the intake manifold as it has a crack in it...I think I was running the blower belt too tight.
I am also looking into a rear disc brake setup as I will have the rear end out to weld up the ladder bar and shock mounts.
I live in Sacramento Ca but work is based out of Orlando Fl so I don't get home all the often to work on it. Hopefully at Thanksgiving and Christmas time I'll get to work on it. These were when it was together
