Dang it!! Who told you???I'm pretty sure he sold this car and bought a Honda and installed a Huge muffler and living in his moms basement
Well, not the kind of updates that anyone wants to see...
Last night I discovered that the rearend in my ‘02 Cummins is starting to bind up, so I parked the truck and the Duster got bumped up to daily driver status. Well that’s not all around terrible. Right?
Well today I’d put about 70 miles on the Duster and was cruising along when suddenly the was a ruckus and commotion and it started riding rough. I thought maybe a u-joint let loose. As I was slowing to come to a stop, the back end of the car bounced up, then slammed down and I see the drivers rear tire rolling on the road behind me. A vehicle passes me going the other way then I see the drum roll off. Finally grind to a stop on a fairly busy two lane highway with no shoulder.
A passing vehicle stopped and the passenger jumped out to stop traffic (gotta love the south) and and an idiot in an suv, paying no attention very nearly rearended me.
Once I got out, I discovered the lugnuts that held the 5x4/5x4.5 adapter/spacer to the axle came loose, causing the spacer and wheel to come off, buggering up my quarter panel. Probably should’ve checked the torque on those lugs periodically, at least I haven’t replaced the quarter panels yet!
So now I need to chase the thread on a few of the studs and get some new lug nuts. If I had the money, now would be the time to upgrade to rear discs and bbp axles but rebuilding my truck rearend is of higher importance right now.
Anyway, here are some pics. I didn’t get any of the wheel or spacer, was more concerned with getting the wheel back on and limping it up the road a little ways to a buddy’s shop.
View attachment 1715348371 View attachment 1715348372
No, this is exactly why I’m alright with it not being all painted up and shiny. It sucks that this happened but if I’d have the body and paint work done, I’d be pissed and sick! LolIf you had put some shiney paint on the poor Duster it never would have happened!!!! LOL
Or as Forrest Gump said, right after he made his first million, :Chit happens!?" lol
That’s for sure!! I was taking some curves pretty hard earlier, had it come off then it could’ve been really bad. Also, I’m thankful that when my wheel crossed the other lane there wasn’t any oncoming traffic.At least you are ok and those around you.
Hahaha! Love it! Although I had to make a small change.Reminds me of the old classic song
"You picked a fine time to leave me loose wheel"
With 3 missing lugnuts an crusing in 5th gear.
Well, not much to post on here other than the fact that I got the spacer and wheel back on and tightened up with new lug nuts. I’ll pull the wheel in a few hundred miles and re-torque the spacer like I should’ve done to start with. My one muffler is completely rusted out and the exhaust is annoyingly hitting the trans crossmember so I need to clearance that and change mufflers. Also need new tires, install my QA1 UCAs and get an alignment.
I actually just bought a pair of 2.25” jegs deep tone chambered mufflers yesterday for $40. Not sure how they’re gonna sound but gotta be better than one solid muffler and one rusted out muffler. LolWhat kind of mufflers would you like? I could help you out with that...
I know they had been tight because I was there when the car was aligned and he torqued those cams GOOD when he was done. I’ll grab new lock washers tomorrow as well. Can’t wait to see how much better the handling is again after this is all done.
He claimed I had the lock washers in the wrong place on the cam bolts and they wouldn’t allow the cam bolt to turn properly (I put the lock washer between the cam washer and the nut, just like every single photo I’ve ever seen) he didn’t charge me anything since he wasn’t happy with how it turned out and he ran out of time. So next Tuesday I’ll take it back in and I’m gonna stay there and offer any help or input that is needed. Here’s the printout.
I got curious and googled the Robertson & Co. sign and found this.I bet there is some good stories about those old buildings.
