My Engine Pics
superchargeddrt
Pittsburgh, Pa.
Hi All,
A few of you wanted to see pictures of my engine so I've attached a couple to this post.
THAT IS FREAKIN AWSOME what year dart and WELCOME
Wow man!
Tell us more about the motor build up.
Got any pics of the whole car?
Hello Cudaspaz,
Thanks for the complement. I've been working on this car since 1981. I've listed most of the engine build below and I'll post a few more pics of my car Thanks Again!
Balanced 340 engine, 8.5:1 TRW pistons with Total Seal Gapless rings, Custom ground Comp Cams roller cam, and solid roller lifters, Crane 1.5 roller rockers, 340 X heads with stainless steel valves and hardened seats The heads have six angle valve job and are ported, Crane 6AL ignition with Taylor 10mm wires, Transmission is a TCI Streetfighter with a reversed manual valve body and a 3200 stall converter, The rear end is a 8 3/4 with 3.55:1 ratio (just changed from 4.30's)
Welcome to FABO.Not much I can say that hasn'tt already been said but what the hell,man that is a Saweeeeeeeeeeeet ride!8)
