JamesRR
84 dodge d150 with a 1973 360. A little bit of cam. Carter AFB carburetor. stock heads. Mopar distributor with orange box... Truck was running excellent. For miles and miles. Went to start it the other day and it wouldnt start. Went out the day after and it started and all seemed well. Normal warm up procedure per usual. bump the pedal to release the choke and it died. Started right back up and ran for a little. I revved it up and there was a popping/missing/coughing effect. Let the throttle off and it wants to die. Then when I try to give it gas again it dies instantly. Black soot in the primary section of the carburetor. timing is set about 9-10 initial and then 34ish all in. rotor pointing at #1 at TDC. Are all MP distributors curved like this? I think the engine would like more initial. anywho.. I checked to make sure the balancer was in its correct place today and it was. It has not jumped time. Pulled #1 plug only and it looks redish brown. Not oily. I will check the others and pull the carb next. I also have a brand new distributor from 4secondsflat laying around and plan to put that in because the mopar distributor looks like its seen some miles. I did notice when playing with the timing that the current distributor did not want to spin very freely. I will dig into it more but wanted to know if anyone has experienced anything like this. Went from bitchin to a ***** in moments. Thanks
James
James
