[WANTED] Need 318 Oil Filter Nipple & Plate
JeffreysDart
Redwood City CA
Rating - 0%
0   0   0
Hi All, i dropped my engine in with a right angle adapter and its never gonna work. it runs right into the exhaust. I need to go back to original plate and nipple that goes right up to the block. Can someone tell me where i can get the plate & nipple and any other needed gaskets? I see Summit has the nipple but can't locate the plate.
Thanks
-Jeff
If you loosen the center bolt on the adapter, you can usually rotate the filter to a position that will work with your exhaust.
Show us some pictures, I've never run into the problem of the 90* adapter not fitting.
Nipples.
