Hi all,
Newbie here. I have a '68 Barracuda Fastback with a '68 (April) 273 (original 318 gave up the ghost a long time ago).
Engine was "refreshed" a couple of years back, from the previous owner:
"Took engine apart to short block, flushed cooling passages, cleaned carbon and 'lapped' valves, all new seals and gaskets. Engine was clean when taken apart. Only removed top end of engine and oil pan. I pulled engine out of a 4-door Belvedere. It had headers and 2-barrel carb. With a/c to weigh down, ran pretty strong in that car, I just chocked it down with single exhaust. Cleaned carbon from piston top and valves, opened up heat crossover in the intake."
(Note: the engine now has exhaust manifolds instead of headers and a Holley 2-bbl (2280, I think?)).
Ever since I got the car (6 months), it has pinged on part-throttle. Full throttle, fine, no ping.
Initially played with the timing. Everything from 5 ATDC to 20 BTDC (initial/mechanical, and with vacuum advance disconnected/plugged). Still pinged.
Tried the mixture screws on the carb thinking it was running lean, no noticeable improvement.
Went to a one-step "colder" plug NGK ZFR5N (from NGK GR4GP) recently (about 50 miles ago), no noticeable help.
Went to 100 octane racing gas (4 gallons) mixed with Super 91 or 92 octane (can't remember, 14 gallons). This was the biggest help. But impractical as racing gas is 4x more expensive!
I can move the heat riser/flapper by hand (with motor off), so I don't think that's stuck to cause a lean condition...
I don't detect any vacuum leaks (removed and plugged the line to the power booster and still pinged, also sprayed starter fluid around the base of the carb, manifold, etc. without effect).
I read about a plug in the manifold here (a little past midway down the page "Pinging on V-8s") that may be a cause of a lean condition. But then read here and am confused. Is there an EGR valve on the '68 273? Could this be the problem?
I'm pretty desperate at this point as I thought retarding the timing would have solved this.
Any advice GREATLY appreciated.
Thanks,
Paul
P.S. What does "opened up the heat crossover in the intake" mean? Could that be related to my problem?
Thanks,
Paul
