LuckyJackson
Run into a Couple of problems on 1971 Demon 340.
1) Throttle cable snapped. I've Installed a new one but I'm wondering where it meets the firewall....Is there supposed to be a grommet there? When I removed the broken one, the stopper disc on the old cable was kind of stuck in some black goop on firewall. Is that the remnants of a grommet melted by 50+ years of engine heat? Or are you supposed to put some Seam sealer/caulking/gasket stuff on that spot so the disc adheres to it and stays flush? Or does the pressure hold it to the firewall?
2) I'm trying to install an oil pressure sending unit (because it didn't have one). It's a 340 with a rally dash....so I have a gauge. The car has an Edelbrock LD340 intake manifold that may have been from the factory/dealer, or at least has been on 50 years.
Which raised post on the manifold does it go on? The one in the back without the bolt, or the post with the bolt a few inches toward the carb? Also the unit (part #2495222) won't fit in either post because the threaded rod to insert in the manifold is a bigger size (presumably for a stock manifold).
Am i supposed to use an adopter? Are there such things? Is there a corresponding sending unit that I'm supposed to get?
There must be others who have these hi rise manifolds....What are you using for a sending unit when you have an oil pressure gauge, and not a light? Any help on these issues is appreciated. Thanks.
